Zum Hauptinhalt wechseln
How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: Schritt 1, Bild 1 von 1
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: Schritt 2, Bild 1 von 1
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: Schritt 3, Bild 1 von 2 How to Fix a Loose Cookware Lid Handle: Schritt 3, Bild 2 von 2
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: Schritt 4, Bild 1 von 2 How to Fix a Loose Cookware Lid Handle: Schritt 4, Bild 2 von 2
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: Schritt 5, Bild 1 von 3 How to Fix a Loose Cookware Lid Handle: Schritt 5, Bild 2 von 3 How to Fix a Loose Cookware Lid Handle: Schritt 5, Bild 3 von 3
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: Schritt 6, Bild 1 von 2 How to Fix a Loose Cookware Lid Handle: Schritt 6, Bild 2 von 2
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: Schritt 7, Bild 1 von 3 How to Fix a Loose Cookware Lid Handle: Schritt 7, Bild 2 von 3 How to Fix a Loose Cookware Lid Handle: Schritt 7, Bild 3 von 3
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
Abschluss
Dinuk Warnapura
145 Reputation
1 Anleitung geschrieben
York University, Team S1-G29, O'Regan Winter 2021 Mitglied von York University, Team S1-G29, O'Regan Winter 2021
YORK-O'REGAN-W21S1G29
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 76
Insgesamt: 1,928
