Zum Hauptinhalt wechseln
How to Fix a Loose-Fitting Lifting Belt
Was du brauchst
  1. How to Fix a Loose-Fitting Lifting Belt, How to Fix a Loose-Fitting Lifting Belt: Schritt 1, Bild 1 von 1
    • Grab the lifting belt with the latch facing you.
  2. How to Fix a Loose-Fitting Lifting Belt: Schritt 2, Bild 1 von 1
    • Flip over the lifting belt, locating the back side of the latch.
  3. How to Fix a Loose-Fitting Lifting Belt: Schritt 3, Bild 1 von 3 How to Fix a Loose-Fitting Lifting Belt: Schritt 3, Bild 2 von 3 How to Fix a Loose-Fitting Lifting Belt: Schritt 3, Bild 3 von 3
    • In a counter-clockwise rotation, unscrew both of the screws holding the latch in place.
  4. How to Fix a Loose-Fitting Lifting Belt: Schritt 4, Bild 1 von 3 How to Fix a Loose-Fitting Lifting Belt: Schritt 4, Bild 2 von 3 How to Fix a Loose-Fitting Lifting Belt: Schritt 4, Bild 3 von 3
    • Once the screws have been removed, remove both sides of the latch from the belt.
  5. How to Fix a Loose-Fitting Lifting Belt: Schritt 5, Bild 1 von 2 How to Fix a Loose-Fitting Lifting Belt: Schritt 5, Bild 2 von 2
    • Align the latch to the corresponding holes for the desired fit.
    • Make sure to align both sides of the latch to the same holes.
  6. How to Fix a Loose-Fitting Lifting Belt: Schritt 6, Bild 1 von 2 How to Fix a Loose-Fitting Lifting Belt: Schritt 6, Bild 2 von 2
    • In a clockwise rotation, screw both of the screws securely in place.
  7. How to Fix a Loose-Fitting Lifting Belt: Schritt 7, Bild 1 von 2 How to Fix a Loose-Fitting Lifting Belt: Schritt 7, Bild 2 von 2
    • Once screws have been secured, attach the latch and secure the belt.
Abschluss
Samuel Garibay
147 Reputation
1 Anleitung geschrieben
Colorado Springs, Team 1-9, Kiser Spring 2025 Mitglied von Colorado Springs, Team 1-9, Kiser Spring 2025
UCCS-KISER-S25S1G9
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 140
