Einleitung
Your BMW X3 xDrive30i will let you know immediately when you have a low tire pressure. When you turn on your ignition, a yellow warning light will appear on your display. An image will also be displayed showing you exactly which tire needs attention. With a basic air compressor, it’s easy to fill the tires to the correct pressure, and it's even easier to reset the Tire Pressure Monitor.
Tire pressure can fluctuate throughout the seasons, and it’s dangerous to drive on a low tire so be sure to always keep your tires at the correct tire pressure.
Was du brauchst
Push the tire chuck onto the valve stem, making sure that it is secure, and you can hear air entering the tire.
Remove the tire chuck from the valve stem.
Check the tire pressure using the tire pressure gauge by pressing the gauge onto the valve stem.
If the tire pressure is below 32 psi, continue filling the tire with the air compressor.
Once the tire pressure reaches 32 psi, replace the cap back on the valve stem.
Inside the car, using the control wheel, select Vehicle Info on the iDrive screen.
Drive the car to a speed of at least 20 mph until a message appears on the display that indicates that the reset is in process.
After 30 seconds of driving, you will see a new message: All Systems OK, confirming that the tire pressure reset has been successfully completed.
Resetting your tire pressure on your BMW X3 is easy to do following these simple steps and photos.
