Zum Hauptinhalt wechseln
How to Fix a Noisy/Squeaky Bicycle Chain
Was du brauchst
  1. How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 1, Bild 1 von 3 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 1, Bild 2 von 3 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 1, Bild 3 von 3
    • Place a piece of cardboard under the bicycle to catch excess cleaner.
    • Rotate the foot pedal with your hand slowly, and spray WD-40 bicycle chain cleaner evenly throughout the chain.
    • Only use WD-40 that is specifically made for bicycles. Using normal WD-40 can damage your bicycle chain.
    • The chemical spray is toxic and very unpleasant to smell. Please use a mask or other means of protection on your face and eyes.
  2. How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 2, Bild 1 von 3 How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 2, Bild 2 von 3 How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 2, Bild 3 von 3
    • Use bicycle cleaning tools to clean the bicycle chain, the chainrings, the cogset, and front & rear derailleurs until most of the rust is gone.
    • Some bicycles do not have all of these parts.
  3. How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 3, Bild 1 von 2 How to Fix a Noisy/Squeaky Bicycle Chain: Schritt 3, Bild 2 von 2
    • Check your chain system, not only on the chain, but also on the chainrings, cogset, and derailleur system. Sometimes this part will also make noises because of rust.
    • Drip the WD-40 bicycle lubricant on one spot of the chain and rotate the foot pedal until the whole chain is lubricated.
    • Repeat this process until the chain no longer squeaks.
Ziellinie
Jiaming Liu
97 Reputation
1 Anleitung geschrieben
York University, Team S1-G12, Melo-Thaiss Fall 2020 Mitglied von York University, Team S1-G12, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S1G12
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 2,469
