Zum Hauptinhalt wechseln
How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
Was du brauchst
  1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 1, Bild 1 von 1
    • Press Stop to cancel the print job.
  2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 2, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 2, Bild 2 von 2
    • Turn off the printer.
    • Unplug your printer from the power source.
  3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 3, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 3, Bild 2 von 2
    • Open the front tray and check for jammed paper.
    • If you don't see any jammed paper, skip to step 5.
  4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 4, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 4, Bild 2 von 2
    • Pull the paper out slowly using both of your hands to avoid tearing.
    • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
    • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
  5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 5, Bild 1 von 3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 5, Bild 2 von 3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 5, Bild 3 von 3
    • Lay the printer on its backside to expose the bottom panel.
    • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
  6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 6, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 6, Bild 2 von 2
    • Lift off the transport unit cover.
    • Be gentle while removing the cover. You don't want to damage it.
  7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 7, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove any remaining paper gently either using your fingers or a pair of tweezers.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S1-G98, Woodhouse Fall 2020 Mitglied von York University, Team S1-G98, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G98
1 Mitglied
3 Anleitungen geschrieben
7 Kommentare
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - Antwort
it still has the two lights blinking
kresge - Antwort
directions did not help, the yellow and ogange till blinks
kresge - Antwort
it did not work
kresge - Antwort
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 37
Letzte 30 Tage: 235
Insgesamt: 11,749
