Zum Hauptinhalt wechseln
How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
Was du brauchst
    1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 1, Bild 1 von 1
      • Press Stop to cancel the print job.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 2, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 2, Bild 2 von 2
      • Turn off the printer.
      • Unplug your printer from the power source.
      Frag FixBot
    3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 3, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 3, Bild 2 von 2
      • Open the front tray and check for jammed paper.
      • If you don't see any jammed paper, skip to step 5.
      Frag FixBot
    4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 4, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 4, Bild 2 von 2
      • Pull the paper out slowly using both of your hands to avoid tearing.
      • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
      • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
      Frag FixBot
    5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 5, Bild 1 von 3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 5, Bild 2 von 3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 5, Bild 3 von 3
      • Lay the printer on its backside to expose the bottom panel.
      • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
      Frag FixBot
    6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 6, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 6, Bild 2 von 2
      • Lift off the transport unit cover.
      • Be gentle while removing the cover. You don't want to damage it.
      Frag FixBot
    7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 7, Bild 1 von 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: Schritt 7, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Remove any remaining paper gently either using your fingers or a pair of tweezers.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S1-G98, Woodhouse Fall 2020 Mitglied von York University, Team S1-G98, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G98
1 Mitglied
12 Anleitungen geschrieben
7 Kommentare zur Anleitung
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - Antwort Teilen
it still has the two lights blinking
kresge - Antwort Teilen
directions did not help, the yellow and ogange till blinks
it did not work
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 48
Letzte 30 Tage: 173
Insgesamt: 17,669
