Zum Hauptinhalt wechseln
How to Fix a Razer Naga Trinity Click Button
Was du brauchst
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: Schritt 1, Bild 1 von 3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: Schritt 1, Bild 2 von 3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: Schritt 1, Bild 3 von 3
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: Schritt 2, Bild 1 von 2 How to Fix a Razer Naga Trinity Click Button: Schritt 2, Bild 2 von 2
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: Schritt 3, Bild 1 von 2 How to Fix a Razer Naga Trinity Click Button: Schritt 3, Bild 2 von 2
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: Schritt 4, Bild 1 von 1
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: Schritt 5, Bild 1 von 2 How to Fix a Razer Naga Trinity Click Button: Schritt 5, Bild 2 von 2
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: Schritt 6, Bild 1 von 3 How to Fix a Razer Naga Trinity Click Button: Schritt 6, Bild 2 von 3 How to Fix a Razer Naga Trinity Click Button: Schritt 6, Bild 3 von 3
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: Schritt 7, Bild 1 von 1
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Haoran Ke
283 Reputation
1 Anleitung geschrieben
York University, Team S-12, Woodhouse Winter 2022 Mitglied von York University, Team S-12, Woodhouse Winter 2022
YORK-WOODHOUSE-W22SSG12
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 49
Letzte 30 Tage: 232
Insgesamt: 9,095
