Einleitung
Do you have a ripped tie that needs fixing before your next event? Use this guide to fix a tie that has ripped at the seams.
As ties can be expensive to replace, we intend to show people how they can easily repair their ties with household items. This guide is intended to be quick and easy to follow. By doing so, the tie will continue to be used for a long time.
Experience with sewing or enough practice may be helpful in attempting this guide, but not necessary.
Was du brauchst
Gather your cut thread and needle.
Loop your thread through the eye of the needle.
Pull the thread until it is even on both ends.
Poke your needle from the inside of the tie.
Pull the thread all the way through until it reaches the tied knot.
Leave about 1/4 inches from the original hole.
Poke your needle from the outside of the tie and pull thread until knot.
Once the entire seam has been sewn, create a loop with the thread.
To tie a knot, bring your needle through the loop and pull.
Repeat the knot 2-3 more times.
