Zum Hauptinhalt wechseln
How to Fix a Ripped Stuffed Animal
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: Schritt 1, Bild 1 von 3 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: Schritt 1, Bild 2 von 3 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: Schritt 1, Bild 3 von 3
    • Use Polyester Fiberfill stuffing to fill the stuffed bear via rip. Add more stuffing for a firmer toy.
    • Do not overfill the toy, or it may rip again.
  2. How to Fix a Ripped Stuffed Animal: Schritt 2, Bild 1 von 1
    • Insert a thread through the eye of the needle (the hole) and tie it tightly to the needle.
  3. How to Fix a Ripped Stuffed Animal: Schritt 3, Bild 1 von 1
    • Make a knot at the loose end of the thread.
    • This is so that the thread doesn't slip through the cloth while sewing up the bear.
  4. How to Fix a Ripped Stuffed Animal: Schritt 4, Bild 1 von 3 How to Fix a Ripped Stuffed Animal: Schritt 4, Bild 2 von 3 How to Fix a Ripped Stuffed Animal: Schritt 4, Bild 3 von 3
    • Push needle through the end of the rip.
    • Continue along the seam, putting the needle through both sides of the rip to create a stitch.
  5. How to Fix a Ripped Stuffed Animal: Schritt 5, Bild 1 von 2 How to Fix a Ripped Stuffed Animal: Schritt 5, Bild 2 von 2
    • After the rip is sewn shut, tie the end of the thread by creating a knot
    • Create the knot by wrapping the thread around the needle several times Then pull the thread through to secure the knot at the base.
    • Once is enough, but for more security, you can repeat this step twice.
  6. How to Fix a Ripped Stuffed Animal: Schritt 6, Bild 1 von 3 How to Fix a Ripped Stuffed Animal: Schritt 6, Bild 2 von 3 How to Fix a Ripped Stuffed Animal: Schritt 6, Bild 3 von 3
    • Cut any excess thread and you're done!
    • Enjoy your repaired stuffed bear!
Abschluss
Megan Nash
108 Reputation
1 Anleitung geschrieben
Oakland University, Team 6-1, Walwema Winter 2016 Mitglied von Oakland University, Team 6-1, Walwema Winter 2016
OAK-WALWEMA-W16S6G1
10 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 213
