Zum Hauptinhalt wechseln
How to Fix a Skewed Wheel on a Children's Kick Scooter
Was du brauchst
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 1, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 1, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 1, Bild 3 von 3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 2, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 2, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 2, Bild 3 von 3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 3, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 3, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 3, Bild 3 von 3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 4, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 4, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 4, Bild 3 von 3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 5, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 5, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 5, Bild 3 von 3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 6, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 6, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 6, Bild 3 von 3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 7, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 7, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 7, Bild 3 von 3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 8, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 8, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 8, Bild 3 von 3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 9, Bild 1 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 9, Bild 2 von 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: Schritt 9, Bild 3 von 3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Ziellinie
Amir Issagali
169 Reputation
1 Anleitung geschrieben
York University, Team S1-G14, O'Regan Winter 2021 Mitglied von York University, Team S1-G14, O'Regan Winter 2021
YORK-O'REGAN-W21S1G14
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 33
Insgesamt: 1,450
