Einleitung
If your Children's Four-Wheeled Toy Kick Scooter (Velocity Scooter 22, or any kick scooter with two front wheels) isn’t balanced and falls on one of its sides, that means the spring inside the scooter was bent. Therefore, this step-by-step guide will show you how to fix your wonky-wheeled scooter to its proper form.
Was du brauchst
Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Insert the spring into the center section of the wheels.
Slide the two rings on the sides of the wheels into the two rods.
Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
