Einleitung
Slipped bike chains may be caused by several different problems including poor shifting technique, the chain being too long, or a worn out chain or rear casters.
Was du brauchst
Before getting off the bike, downshift bike into lowest front gear (using the left shifter).
Continue pedaling. This step alone may realign the chain.
If Step 1 did not work, get off the bike and lift the rear tire while spinning the pedals with your hand.
If Step 2 is not enough, push rear derailleur forward to release tension on the chain.
Lift the chain and put it back on the chain ring.
Turn the pedals with your hand while lifting the rear wheel to realign the chain (as in Step 2).
Put the chain on the outer chain guide of the chain breaker.
Turn the handle on the chain breaker to push the chain pin part of the way out.
Feed the chain along the guide pulley (the highest of the two pulleys).
Thread the chain inside the derailleur cage in between the tension and guide pulley.
Thread the chain in front of the tab.
Then, thread the chain over the tension pulley.
To rejoin the chain, align the open ends of the chain.
Put the chain on the outer guide of the chain breaker with the pin facing the driving pin.
Turn the driving pin until the pin is equally spaced in between the face plates like all of the other links.
Wiggle the link you just reattached. If it's too stiff, continue on to the next part.
Put the chain on the inside guide of the chain breaker and turn the driving pin just a little. Check as you go along and continue until proper looseness is achieved.
If your chain continues to slip, the chain or cogs are probably worn out. Have a local mechanic look at your bike and determine which needs to be replaced. If it's the chain, visit this guide <Triace A310 Chain Replacement>
21 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Thank you so much for this article--so many helpful tips here. But, I just saw this post ("Over 200 Bike Repair Videos and Hundreds of Pages of Illustrated Guides") and actually was reading about this same topic the other day. I did some searching around and stumbled onto this cool article… I thought it was helpful… http://diybikerepairguide.weebly.com
Thanks for the information. How do I know how long the new chain should be. Hint, don't have broken one.
Thanks for your post. A bicycle normally drops off a gear or chain ring as the teeth have worn and become narrow.The chain has a bad link and stretched. To increase complexity, you have lots of options to ensure the dropped chain. You may like this too- http://www.mybiked.com/rechain-bike-usef...
I have a chain guide on my bike only now that the chain is off, I can’t seem to lift the chain onto the top of the chain ring as the guide is blocking this.
