Zum Hauptinhalt wechseln
How to Fix a Slipping Violin Peg
Was du brauchst
  1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: Schritt 1, Bild 1 von 3 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: Schritt 1, Bild 2 von 3 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: Schritt 1, Bild 3 von 3
    • Completely unwind the string affected by the loose peg.
    • Turn the peg clockwise for strings G and D and counterclockwise for strings A and E.
  2. How to Fix a Slipping Violin Peg: Schritt 2, Bild 1 von 1
    • Slide the peg out towards you to remove it from the pegbox.
    • The pegbox contains the holes that the pegs go into.
  3. How to Fix a Slipping Violin Peg: Schritt 3, Bild 1 von 2 How to Fix a Slipping Violin Peg: Schritt 3, Bild 2 von 2
    • Locate the points on the peg that come into contact with the pegbox.
    • Rub the peg compound all the way around the peg on the points that contact the pegbox.
  4. How to Fix a Slipping Violin Peg: Schritt 4, Bild 1 von 3 How to Fix a Slipping Violin Peg: Schritt 4, Bild 2 von 3 How to Fix a Slipping Violin Peg: Schritt 4, Bild 3 von 3
    • Reinsert the peg by pushing inwards.
    • Turn the peg counterclockwise or clockwise to evenly distribute the compound.
  5. How to Fix a Slipping Violin Peg: Schritt 5, Bild 1 von 2 How to Fix a Slipping Violin Peg: Schritt 5, Bild 2 von 2
    • Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
  6. How to Fix a Slipping Violin Peg: Schritt 6, Bild 1 von 3 How to Fix a Slipping Violin Peg: Schritt 6, Bild 2 von 3 How to Fix a Slipping Violin Peg: Schritt 6, Bild 3 von 3
    • Locate the hole on the peg and insert the string through it.
    • Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
    • The scroll is the woodcarving at the top of the violin.
    • After one or two turns, angle the string toward the peg head (vertical alignment).
  7. How to Fix a Slipping Violin Peg: Schritt 7, Bild 1 von 2 How to Fix a Slipping Violin Peg: Schritt 7, Bild 2 von 2
    • Tune the string.
    • For strings A and E, tightly turn the peg clockwise, and for strings G and D, turn the peg counterclockwise.
Abschluss
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 82
