Einleitung
If your violin is not producing the desired tune due to a loose string that will not tighten despite adjustment, use this guide to fix your loose violin peg.
Each string on the violin is attached to a peg that allows you to tune it. If your string is continually loose, then a loose peg is the issue. Rewinding the string completely and administering peg compound ensures the correct position to hold the peg in place in order for your violin to fully function. Using one of these methods over the other can also serve as a solution; however, it is best to do both.
Was du brauchst
Completely unwind the string affected by the loose peg.
Locate the points on the peg that come into contact with the pegbox.
Rub the peg compound all the way around the peg on the points that contact the pegbox.
Reinsert the peg by pushing inwards.
Turn the peg counterclockwise or clockwise to evenly distribute the compound.
Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
Locate the hole on the peg and insert the string through it.
Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
After one or two turns, angle the string toward the peg head (vertical alignment).
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
