Zum Hauptinhalt wechseln
How to Fix a Squeaky Bed Frame
Was du brauchst
  1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: Schritt 1, Bild 1 von 1
    • Remove anything that is on the bed frame.
  2. How to Fix a Squeaky Bed Frame: Schritt 2, Bild 1 von 1
    • Shake the bed frame to pinpoint the area of noise.
  3. How to Fix a Squeaky Bed Frame: Schritt 3, Bild 1 von 1
    • Identify which type of screw the bedframe uses in the given area.
    • You will need to make use of the corresponding screwdriver throughout the guide.
    • Typically, the bed frame will use the same type of screws throughout.
  4. How to Fix a Squeaky Bed Frame: Schritt 4, Bild 1 von 1
    • Ensure the components of the bed frame are aligned.
    • Identify gaps between parts of the frame.
    • Tighten the screws where gaps are present
    • Sometimes mismatched components cause squeakiness.
  5. How to Fix a Squeaky Bed Frame: Schritt 5, Bild 1 von 1
    • Tighten the screws within the area of noise.
    • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
  6. How to Fix a Squeaky Bed Frame: Schritt 6, Bild 1 von 1
    • Spray WD-40 into all the contact points of the bed frame.
    • This includes screws and intersections of the frame.
    • Be careful of the spray around children and your eyes.
  7. How to Fix a Squeaky Bed Frame: Schritt 7, Bild 1 von 1
    • This is an alternative for the previous step.
    • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
Abschluss
Reassemble the bed to your liking.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team S1-G18, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G18, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G18
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 77
Insgesamt: 1,081
