Zum Hauptinhalt wechseln
How to Fix a Sticking Deadbolt
Was du brauchst
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: Schritt 1, Bild 1 von 2 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: Schritt 1, Bild 2 von 2
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: Schritt 2, Bild 1 von 2 How to Fix a Sticking Deadbolt: Schritt 2, Bild 2 von 2
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: Schritt 3, Bild 1 von 1
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: Schritt 4, Bild 1 von 2 How to Fix a Sticking Deadbolt: Schritt 4, Bild 2 von 2
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: Schritt 5, Bild 1 von 1
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: Schritt 6, Bild 1 von 2 How to Fix a Sticking Deadbolt: Schritt 6, Bild 2 von 2
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: Schritt 7, Bild 1 von 2 How to Fix a Sticking Deadbolt: Schritt 7, Bild 2 von 2
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: Schritt 8, Bild 1 von 1
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: Schritt 9, Bild 1 von 3 How to Fix a Sticking Deadbolt: Schritt 9, Bild 2 von 3 How to Fix a Sticking Deadbolt: Schritt 9, Bild 3 von 3
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: Schritt 10, Bild 1 von 1
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
Abschluss
After following this fast fix guide, the sticking deadbolt should be fixed.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Texas Tech, Team 22-5, Rauch Spring 2016 Mitglied von Texas Tech, Team 22-5, Rauch Spring 2016
TTU-RAUCH-S16S22G5
3 Mitglieder
1 Anleitung geschrieben
Ein Kommentar
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 28
Letzte 30 Tage: 140
Insgesamt: 39,071
