Einleitung
Fixing a sweater snag is a relatively simple procedure that most people can accomplish with the proper equipment at home. This guide will ensure that you know to how to repair your sweater to increase its longevity while enabling you to get the most wear out of your sweater as well.
Was du brauchst
Using scissors, cut thread that matches the color of your sweater.
Pull the needle through the sweater at the site of the snag, ensuring that the needle is facing the inside of the sweater.
Ensure that you have enough thread to work with.
Loop the snag around the needle.
Begin to pull the needle through the snag to the other side.
Once again, face the needle towards the inside of the sweater then pull the needle through the site of snag.
Cut the loose thread.
Make sure there is enough thread sticking out from where the snag was.
