Zum Hauptinhalt wechseln
How to Fix a Thrustmaster Eswap X Pro Controller Trigger
Was du brauchst
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 1, Bild 1 von 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 1, Bild 2 von 2
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 2, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 2, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 2, Bild 3 von 3
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 3, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 3, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 3, Bild 3 von 3
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 4, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 4, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 5, Bild 1 von 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 6, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 6, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 6, Bild 3 von 3
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 7, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 7, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 7, Bild 3 von 3
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 8, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 8, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 8, Bild 3 von 3
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 9, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 9, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 9, Bild 3 von 3
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 10, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 10, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 10, Bild 3 von 3
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 11, Bild 1 von 1
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 12, Bild 1 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 12, Bild 2 von 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: Schritt 12, Bild 3 von 3
    • Reattach the magnetic side cover.
    • The controller is fixed!
Abschluss
Laurence Chan
205 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-3, Morris Winter 2023 Mitglied von UC Davis, Team 2-3, Morris Winter 2023
UCD-MORRIS-W23S2G3
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 35
Letzte 30 Tage: 137
Insgesamt: 2,115
