Zum Hauptinhalt wechseln
How to Fix a Tunneling Candle
Was du brauchst
  1. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: Schritt 1, Bild 1 von 3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: Schritt 1, Bild 2 von 3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: Schritt 1, Bild 3 von 3
    • Fill any kind of dish with hot water.
    • Add any brand of dish soap or hand soap to the water.
    • Mix the soap with water using a spoon.
  2. How to Fix a Tunneling Candle: Schritt 2, Bild 1 von 2 How to Fix a Tunneling Candle: Schritt 2, Bild 2 von 2
    • Place the candle inside the mix of water and soap.
    • Let the jar soak inside the pot.
    • Make sure the area on the jar that has a label is completely soaked.
    • After 5 to 10 minutes, remove the candle from the dish.
  3. How to Fix a Tunneling Candle: Schritt 3, Bild 1 von 1
    • Use a sponge to wash and remove the label from the jar.
    • Removing the label helps you have a cleaner fix as it prevents the label from peeling off inside the boiling water and damaging your pot in future steps.
  4. How to Fix a Tunneling Candle: Schritt 4, Bild 1 von 3 How to Fix a Tunneling Candle: Schritt 4, Bild 2 von 3 How to Fix a Tunneling Candle: Schritt 4, Bild 3 von 3
    • Fill another pot with water and place it on the stove.
    • Turn the stove to high heat.
    • Wait until the water is simmering.
  5. How to Fix a Tunneling Candle: Schritt 5, Bild 1 von 3 How to Fix a Tunneling Candle: Schritt 5, Bild 2 von 3 How to Fix a Tunneling Candle: Schritt 5, Bild 3 von 3
    • Use oven mitts to place the candle inside the pot.
    • Wait 15 to 30 minutes for the wax to be fully melted.
  6. How to Fix a Tunneling Candle: Schritt 6, Bild 1 von 3 How to Fix a Tunneling Candle: Schritt 6, Bild 2 von 3 How to Fix a Tunneling Candle: Schritt 6, Bild 3 von 3
    • While waiting for the wax to melt, grab two coffee stir sticks or similar objects, and tape them into a cross.
    • In this guide, I am using incense sticks.
  7. How to Fix a Tunneling Candle: Schritt 7, Bild 1 von 3 How to Fix a Tunneling Candle: Schritt 7, Bild 2 von 3 How to Fix a Tunneling Candle: Schritt 7, Bild 3 von 3
    • Take the candle out of the pot using oven mitts.
    • Place the melted candle on a flat surface.
    • Remember to turn off the stove.
  8. How to Fix a Tunneling Candle: Schritt 8, Bild 1 von 2 How to Fix a Tunneling Candle: Schritt 8, Bild 2 von 2
    • Use a pair of tweezers to grab and pull out the burnt wick of the candle.
    • Do not touch the hot wax with your fingers; use tweezers.
  9. How to Fix a Tunneling Candle: Schritt 9, Bild 1 von 3 How to Fix a Tunneling Candle: Schritt 9, Bild 2 von 3 How to Fix a Tunneling Candle: Schritt 9, Bild 3 von 3
    • Place the cross that you made from the sticks on the edges of the candle jar.
    • Insert two new candle wicks inside the wax from the metal side.
    • Make sure the wicks are not close together.
    • Twist the wick around the sticks to prevent them from moving.
  10. How to Fix a Tunneling Candle: Schritt 10, Bild 1 von 3 How to Fix a Tunneling Candle: Schritt 10, Bild 2 von 3 How to Fix a Tunneling Candle: Schritt 10, Bild 3 von 3
    • Wait for the wax to harden and remove the sticks.
    • Trim the candle wick to 1/4 inch.
    • You have fixed your tunneling candle.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S1-G22, Woodhouse Winter 2021 Mitglied von York University, Team S1-G22, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G22
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 892
