Zum Hauptinhalt wechseln
How to Fix a Whirlpool WDF330PAHW Door Latch
Was du brauchst
  1. How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 1, Bild 1 von 2 How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 1, Bild 2 von 2
    • Open the dishwasher door and look for the retaining screws around the side edge and top edge of the dishwasher door.
  2. How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 2, Bild 1 von 1
    • Using a T8 Torx screwdriver remove the two screws by turning counter clockwise.
  3. How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 3, Bild 1 von 2 How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 3, Bild 2 von 2
    • Lift the inner panel enough that you can loosen the two securing bolts on the door latch with the wrench.
    • When loosening the two bolts, leave them in and don't remove them.
  4. How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 4, Bild 1 von 2 How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 4, Bild 2 von 2
    • Carefully raise the dishwasher door to align the door latch with the strike plate.
    • Watch fingers while raising dishwasher door.
  5. How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 5, Bild 1 von 1
    • Hold the door latch with your finger tips to align the door latch.
    • Then lower the door and tighten the door latch securing bolts.
  6. How to Fix a Whirlpool WDF330PAHW Door Latch: Schritt 6, Bild 1 von 1
    • Install the inner door panel retaining screws.
    • Proceed to tighten two screws with the T8 Torx screwdriver.
    • When tightening the two screws turn clockwise.
    • Then close the dishwasher door.
Ziellinie
Magdalene Cannon
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 62
Insgesamt: 2,223
