Zum Hauptinhalt wechseln
How to Fix a Wobbling Living Room Table
Was du brauchst
    1. How to Fix a Wobbling Living Room Table, How to Fix a Wobbling Living Room Table: Schritt 1, Bild 1 von 2 How to Fix a Wobbling Living Room Table, How to Fix a Wobbling Living Room Table: Schritt 1, Bild 2 von 2
      • Flip the table over and place it on top of the shelf.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix a Wobbling Living Room Table: Schritt 2, Bild 1 von 2 How to Fix a Wobbling Living Room Table: Schritt 2, Bild 2 von 2
      • Use a Phillips #2 screwdriver to remove the screws from the table leg.
      • Twist the screwdriver to the left (counterclockwise) to loosen the screw.
      Frag FixBot
    3. How to Fix a Wobbling Living Room Table: Schritt 3, Bild 1 von 2 How to Fix a Wobbling Living Room Table: Schritt 3, Bild 2 von 2
      • Remove the cap from the wood glue.
      • Use scissors to cut open the tip so the glue is able to be squeezed out.
      Frag FixBot
    4. How to Fix a Wobbling Living Room Table: Schritt 4, Bild 1 von 2 How to Fix a Wobbling Living Room Table: Schritt 4, Bild 2 von 2
      • Gently squeeze the wood glue into the screw holes.
      Frag FixBot
    5. How to Fix a Wobbling Living Room Table: Schritt 5, Bild 1 von 1
      • Carefully place the leg back into its original position.
      Frag FixBot
    6. How to Fix a Wobbling Living Room Table: Schritt 6, Bild 1 von 2 How to Fix a Wobbling Living Room Table: Schritt 6, Bild 2 von 2
      • Put all the screws back into their original holes. Then use the Phillips #2 screwdriver to tighten each screw.
      • For the back section, use a drill if the screw won't go in with the screwdriver.
      Frag FixBot
    7. How to Fix a Wobbling Living Room Table: Schritt 7, Bild 1 von 3 How to Fix a Wobbling Living Room Table: Schritt 7, Bild 2 von 3 How to Fix a Wobbling Living Room Table: Schritt 7, Bild 3 von 3
      • Place the table in a safe location and let it sit for at least 30 minutes.
      • After the time has passed, flip the table back onto its legs and gently shake it to make sure the glue has set.
      Frag FixBot
Abschluss
Once you have finished this guide, your table should no longer be slanted.
Taurus Black
154 Reputation
1 Anleitung geschrieben
Austin Community College, Team 2-9, Kapoor Spring 2025 Mitglied von Austin Community College, Team 2-9, Kapoor Spring 2025
AUSTINCC-KAPOOR-S25S2G9
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 607
