Zum Hauptinhalt wechseln
How to Fix a Wobbly Leg on a Solid Wood Chair
Was du brauchst
    1. How to Fix a Wobbly Leg on a Solid Wood Chair, How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 1, Bild 1 von 1
      • First, thoroughly assess your chair for loose elements.
      • Sit and jiggle them to test and note exactly what moves.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 2, Bild 1 von 3 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 2, Bild 2 von 3 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 2, Bild 3 von 3
      • Position an L-bracket as if it will brace the leg to the frame of the chair.
      • Mark the exact outline of the bracket, taking extra care when marking the center hole where your screws will hold the brace in place.
      • It might be beneficial to "x" the through the marked circles to approximate the exact center for the screw to enter.
      Frag FixBot
    3. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 3, Bild 1 von 2 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 3, Bild 2 von 2
      • If possible, detach your chair legs.
      • In the case you cannot detach your chair legs, consider buying longer L-brackets so you still have enough room to hold your drill parallel to the chair surfaces.
      Frag FixBot
    4. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 4, Bild 1 von 1
      • Check if the drill bit is longer than the width of the chair leg.
      • If so, consider marking the drill bit to your desired depth.
      Frag FixBot
    5. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 5, Bild 1 von 3 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 5, Bild 2 von 3 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 5, Bild 3 von 3
      • Before drilling any holes, ensure that your drill bit is slightly smaller than the width of your screw. This will result in a more secure hold.
      • Pre-drill holes through the center of your marked circles on both your chair legs and chair frame.
      Frag FixBot
    6. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 6, Bild 1 von 2 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 6, Bild 2 von 2
      • Using the drill, secure your L-brackets to the chair legs first.
      • Be sure to hold the drill and screw parallel to the drilling surface.
      Frag FixBot
    7. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 7, Bild 1 von 1
      • For extra hold and durability, use a small amount of wood glue at the chair legs joints.
      • Be sure to wipe away any excess wood glue.
      Frag FixBot
    8. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 8, Bild 1 von 2 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 8, Bild 2 von 2
      • Tighten any preexisting hardware holding the legs to the chair base before fixing the L-bracket to the chair.
      Frag FixBot
    9. How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 9, Bild 1 von 2 How to Fix a Wobbly Leg on a Solid Wood Chair: Schritt 9, Bild 2 von 2
      • Finally, screw the second side of the L-bracket to the base of the chair.
      Frag FixBot
Abschluss
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
3 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team S2-G6, Cole Spring 2017 Mitglied von UC Davis, Team S2-G6, Cole Spring 2017
UCD-COLE-S17S2G6
3 Mitglieder
1 Anleitung geschrieben
2 Kommentare zur Anleitung
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
Radhika Murali - Antwort Teilen
My neighbor called and said she had a table. She brought it outside but before I could make it across the street someone took the legs. Miraculously I found legs from another table the next day. Unfortunately the screw hole didn’t match. The table was wobbly. This is the almost perfect fix.
WillowBees Naturally - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 52
Letzte 30 Tage: 220
Insgesamt: 38,199
