Zum Hauptinhalt wechseln
How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan
Was du brauchst
  1. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan, How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 1, Bild 1 von 2 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan, How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 1, Bild 2 von 2
    • Prior to starting, turn off and unplug the fan.
  2. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 2, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 2, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 2, Bild 3 von 3
    • Remove the clamp on one side of the fan by turning it counterclockwise.
    • When the clamp is loose enough to be removed, hold the fan cage with your other hand to prevent it from falling right off.
    • Repeat the above process for the other clamp.
  3. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 3, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 3, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 3, Bild 3 von 3
    • Separate the base from the cage of the fan.
  4. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 4, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 4, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 4, Bild 3 von 3
    • Place the fan on the tabletop so that the front grille is facing you.
    • Identify the location of the five screws.
    • This step is crucial because we will want to unscrew the grille diagonally.
    • Unscrew any one of the screws using a Phillips #2 screwdriver.
    • It might also help to hold the fan down with your other hand to avoid movement.
  5. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 5, Bild 1 von 2 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 5, Bild 2 von 2
    • Push up the screw from the bottom to pop it out.
  6. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 6, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 6, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 6, Bild 3 von 3
    • Unscrew the screw located diagonally across from the previous one using a Phillips #2 screwdriver.
    • Diagonally across ensures that the front grille does not experience unequal pressure to help its shape stay intact.
    • Repeat the process for all of the screws.
  7. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 7, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 7, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 7, Bild 3 von 3
    • Remove the front grille from the fan.
  8. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 8, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 8, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 8, Bild 3 von 3
    • Expose the four screws on the impeller assembly by turning the blades.
    • Pick one screw and tighten it a small amount by rotating the screw just once with a Phillips #2 screwdriver.
  9. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 9, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 9, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 9, Bild 3 von 3
    • Move to the screw located diagonally across from the previous one.
    • Tighten the screw the exact same amount as the previous one.
    • Perform the same process for the remaining two screws.
    • Don't overtighten the screws. If the screws are too tight, it might lead to fan vibration.
  10. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 10, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 10, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 10, Bild 3 von 3
    • To ensure that the blades do not move, use one hand to keep them in place.
    • Tighten the set screw between the blades and impeller assembly using a Phillips #2 screwdriver.
    • The set screw is a little hard to reach, so it is crucial to keep the blades still.
  11. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 11, Bild 1 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 11, Bild 2 von 3 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: Schritt 11, Bild 3 von 3
    • Check the tightness of the set screw by pulling the blades up gently.
    • The blades should only lift a minuscule amount when you perform this test. If they do not move at all, the set screw is too tight.
Abschluss
Muhammad Ali Malik
193 Reputation
1 Anleitung geschrieben
York University, Team S2-G14, Melo-Thaiss Fall 2020 Mitglied von York University, Team S2-G14, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G14
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 492
