Zum Hauptinhalt wechseln
How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
Was du brauchst
  1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 1, Bild 1 von 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 1, Bild 2 von 2
    • Lean back the chair and extend the leg rest completely.
  2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 2, Bild 1 von 1
    • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
  3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 3, Bild 1 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 3, Bild 2 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 3, Bild 3 von 3
    • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
  4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 4, Bild 1 von 1
    • Slide the leg rest out of the base.
  5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 5, Bild 1 von 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 5, Bild 2 von 2
    • Place the leg rest on a flat surface.
    • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
  6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 6, Bild 1 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 6, Bild 2 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 6, Bild 3 von 3
    • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
    • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
  7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 7, Bild 1 von 1
    • Slide the leg rest back into the base.
  8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 8, Bild 1 von 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 8, Bild 2 von 2
    • Screw the 3 mm blocker screw back in.
    • Flip your chair back up and enjoy your sturdy leg rest!
Abschluss
Anoop Shahi
157 Reputation
1 Anleitung geschrieben
York University, Team S1-G26, O'Regan Winter 2021 Mitglied von York University, Team S1-G26, O'Regan Winter 2021
YORK-O'REGAN-W21S1G26
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 408
