Zum Hauptinhalt wechseln
How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
Was du brauchst
    1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 1, Bild 1 von 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 1, Bild 2 von 2
      • Lean back the chair and extend the leg rest completely.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 2, Bild 1 von 1
      • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
      Frag FixBot
    3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 3, Bild 1 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 3, Bild 2 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 3, Bild 3 von 3
      • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
      Frag FixBot
    4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 4, Bild 1 von 1
      • Slide the leg rest out of the base.
      Frag FixBot
    5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 5, Bild 1 von 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 5, Bild 2 von 2
      • Place the leg rest on a flat surface.
      • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
      Frag FixBot
    6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 6, Bild 1 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 6, Bild 2 von 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 6, Bild 3 von 3
      • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
      • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
      Frag FixBot
    7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 7, Bild 1 von 1
      • Slide the leg rest back into the base.
      Frag FixBot
    8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 8, Bild 1 von 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: Schritt 8, Bild 2 von 2
      • Screw the 3 mm blocker screw back in.
      • Flip your chair back up and enjoy your sturdy leg rest!
      Frag FixBot
Abschluss
Anoop Shahi
157 Reputation
1 Anleitung geschrieben
York University, Team S1-G26, O'Regan Winter 2021 Mitglied von York University, Team S1-G26, O'Regan Winter 2021
YORK-O'REGAN-W21S1G26
1 Mitglied
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 40
Insgesamt: 1,025
