Einleitung
Follow this guide to fix a jammed OXO POP container's button. (Skip to step 4 if the button is not jammed and stays protruded.) The OXO POP container is a one-handed airtight storage most commonly used in the kitchen for storing foods. Additionally, it is handy for tidying up and organizing outside the kitchen. This specific container we worked on was bought from Costco, though it can also be found at most department stores or home improvement retailers, such as Target and Home Depot.
There are little metal prongs attached underneath the button that catch onto a mechanism in the lid. Sometimes, the prongs will bend after constant usage, causing the button to become stuck. Fear not! This can be easily fixed by taking the lid apart and bending the prongs back into the right shape. (Refer to steps 3 and 5 to see how the tools were used.)
Was du brauchst
Hold the lid with the button facing down.
Twist the flat part in the direction of the arrows or counter clockwise.
Firmly pinch both the half-moon shaped openings.
Pull up the removed outer piece and set it aside.
Place the lid perpendicular and onto the top of the container's opening.
Locate the two holes.
With a tool in each hand, insert them into the openings of the buttons.
Firmly press downwards until the button pops out.
Flip the lid so the button faces up.
Pinch the two sides and gently pull up.
Remove the button.
Flip the button so the inside wire faces upwards.
Use pliers to bend the wire similar to its original shape.
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
