Zum Hauptinhalt wechseln
How to Fix an Umbrella Rivet
Was du brauchst
  1. How to Fix an Umbrella Rivet, How to Fix an Umbrella Rivet: Schritt 1, Bild 1 von 1
    • Open the umbrella into its proper position.
  2. How to Fix an Umbrella Rivet: Schritt 2, Bild 1 von 1
    • Identify the broken stretcher that needs to be repaired.
  3. How to Fix an Umbrella Rivet: Schritt 3, Bild 1 von 1
    • Close the umbrella halfway to release the tension in the stretchers.
    • This makes it easier to line up the holes in the next step.
  4. How to Fix an Umbrella Rivet: Schritt 4, Bild 1 von 1
    • Take the two pieces of the broken stretcher and line up the rivet holes.
  5. How to Fix an Umbrella Rivet: Schritt 5, Bild 1 von 1
    • Pass the 6" piece of wire through the rivet holes.
  6. How to Fix an Umbrella Rivet: Schritt 6, Bild 1 von 1
    • Wrap the wire around the stretcher and thread it through the holes again.
    • Repeat until there is no more room to pass the wire through.
    • May need to use the pliers to get a better grip on the wire so it can be pulled tight.
  7. How to Fix an Umbrella Rivet: Schritt 7, Bild 1 von 1
    • Tie two half-hitch knots with the wire.
    • If you do not know how to tie a half-hitch knot, follow the link provided at the beginning of the guide.
  8. How to Fix an Umbrella Rivet: Schritt 8, Bild 1 von 1
    • Use the scissors to trim the two ends of the wire to about half an inch in length.
  9. How to Fix an Umbrella Rivet: Schritt 9, Bild 1 von 1
    • Using the pliers, twist the ends of the wire together.
  10. How to Fix an Umbrella Rivet: Schritt 10, Bild 1 von 1
    • Tuck the wires down and clamp with the pliers so the ends are not poking out.
Ziellinie
6 weitere Personen haben diese Anleitung absolviert.
Texas Tech, Team 3-8, Rauch SU 2016 Mitglied von Texas Tech, Team 3-8, Rauch SU 2016
TTU-RAUCH-SU16S3G8
2 Mitglieder
3 Anleitungen geschrieben
7 Kommentare
This is not called an ‘umbrella rivet replacement’.
SouthPark - Antwort
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
Lou - Antwort
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
Lou - Antwort
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 19
Letzte 7 Tage: 166
Letzte 30 Tage: 818
Insgesamt: 21,565
