Zum Hauptinhalt wechseln
How to Fix an Uneven Guitar Fret
Was du brauchst
  1. How to Fix an Uneven Guitar Fret, How to Fix an Uneven Guitar Fret: Schritt 1, Bild 1 von 2 How to Fix an Uneven Guitar Fret, How to Fix an Uneven Guitar Fret: Schritt 1, Bild 2 von 2
    • Loosen the strings by turning each knob on the left of the guitar counter-clockwise.
    • Loosen until you can fit one finger underneath.
  2. How to Fix an Uneven Guitar Fret: Schritt 2, Bild 1 von 1
    • Locate the general area where the strings are buzzing due to the uneven fret.
    • Place the long side of the fret rocker down over three frets.
    • Rock the fret rocker side to side.
    • If it moves, the fret in the middle of the three is higher than the others.
  3. How to Fix an Uneven Guitar Fret: Schritt 3, Bild 1 von 1
    • Place the fret guard underneath the strings and over the uneven fret.
  4. How to Fix an Uneven Guitar Fret: Schritt 4, Bild 1 von 3 How to Fix an Uneven Guitar Fret: Schritt 4, Bild 2 von 3 How to Fix an Uneven Guitar Fret: Schritt 4, Bild 3 von 3
    • Take one paper towel sheet and fold in half the long way.
    • Roll the paper towel tightly about halfway down the sheet.
    • Cut the paper towel as pictured.
    • Repeat once more, you should have two small paper towel rolls.
  5. How to Fix an Uneven Guitar Fret: Schritt 5, Bild 1 von 1
    • Place the two rolls under the strings around the fret guard.
  6. How to Fix an Uneven Guitar Fret: Schritt 6, Bild 1 von 2 How to Fix an Uneven Guitar Fret: Schritt 6, Bild 2 von 2
    • File the top of the fret in an up down motion
    • Start slow, file back and forth only a couple times then see step 7
  7. How to Fix an Uneven Guitar Fret: Schritt 7, Bild 1 von 1
    • Place the fret rocker over the frets again.
    • If it still rocks, repeat the previous step.
  8. How to Fix an Uneven Guitar Fret: Schritt 8, Bild 1 von 3 How to Fix an Uneven Guitar Fret: Schritt 8, Bild 2 von 3 How to Fix an Uneven Guitar Fret: Schritt 8, Bild 3 von 3
    • Polish the top of the frets by sandpapering the top of the fret in an up/down motion.
    • Stop when fret feels smooth and looks shiny.
Abschluss
Victoria
157 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-1, Whithaus Spring 2024 Mitglied von UC Davis, Team 1-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G1
3 Mitglieder
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 142
