Einleitung
If the Poang-style chair sold by IKEA is assembled incorrectly, it can cause the seat to dip and tip when it's sat on. This guide will describe the steps necessary to fix this problem and otherwise increase the stability of the chair.
Was du brauchst
Start by removing the seat cushion from the frame.
Remove the upper bolt, which attaches the back of the seat to the armrests.
Remove the lower bolt, which is the upper bolt attaching the seat to the legs.
Re-attach the bolts removed in Steps 2 and 3. Put each bolt into the correct location before tightening each bolt.
For maximum stability, fully tighten all of the bolts in the chair.
As shown in the video, tighten by turning the Allen wrench to the RIGHT.
Set the chair cushion on the chair seat.
Secure the Velcro on the cushion to the Velcro on the chair back.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
