Zum Hauptinhalt wechseln
How To Restore True Tone After Screen Replacement On iPhone XS
Was du brauchst
Einführungsvideo
  1. How To Restore True Tone After Screen Replacement On iPhone XS, iPhone XS Aftermarket Screen True Tone Restoration With Original Screen: Schritt 1, Bild 1 von 1
    • Go to Settings>General>About and check the software version of the phone – iOS 13.2. Tap Display & Brightness. We can see that the True Tone has been turned on with the switch being green.
    • Replace with a new aftermarket screen.
    • Tap Display & Brightness. We can see that the true tone option has vanished.
  2. How To Restore True Tone After Screen Replacement On iPhone XS: Schritt 2, Bild 1 von 1
    • Now, let’s restore the true tone with the multi-functional programmer.
    • First, connect the display extended module with the programmer. Next, connect the original screen with the display extended module.
    • Then we need to use the programmer to read data on the original screen.
    • Once finished, disconnect the original screen and connect the aftermarket screen with the display extended module.
    • This time we use the programmer to write the data to the aftermarket screen. Once finished, disconnect the aftermarket screen.
  3. How To Restore True Tone After Screen Replacement On iPhone XS: Schritt 3, Bild 1 von 1
    • Now we can assemble the phone and test.
    • Tap Display & Brightness. We can see this time that the True Tone has been turned on with the switch being green. The True Tone has been restored back.
  4. How To Restore True Tone After Screen Replacement On iPhone XS, iPhone XS Aftermarket Screen True Tone Restoration Without Original Screen: Schritt 4, Bild 1 von 1
    • Go to Settings>General>About and check the software version of the phone – iOS 13.2. Continue to tap Display & Brightness. We can see that there is no true tone option.
    • Connect the phone to the computer and open the WL assistance software. The cover board number of the phone has been read automatically.
    • Continue to power off and disconnect the phone from the computer. Remove the aftermarket screen afterwards.
  5. How To Restore True Tone After Screen Replacement On iPhone XS: Schritt 5, Bild 1 von 1
    • Now, let’s restore the true tone without the original screen.
    • Connect the aftermarket screen with the display extended module and connect the multi-functional true tone programmer to the computer.
    • To restore true tone without the original screen, we need to write the previously read cover board number to the aftermarket screen with the help of the software.
  6. How To Restore True Tone After Screen Replacement On iPhone XS: Schritt 6, Bild 1 von 1
    • Now we can assemble the phone and test. Get the aftermarket screen installed and connect the battery. Press the power button to turn on the phone.
    • Continue to tap Display & Brightness. We can see that the True Tone has been turned on with the switch being green. The True Tone has been restored back.
Phryne
20.329 Reputation
18 Anleitungen geschrieben
26 Kommentare
Would this work with an original screen on another body?
suensonvictor - Antwort
this aftermarket LCM. literally it does not have true tone functioning.
yrcooler - Antwort
Really nice fix!
I had installed an original iPhone screen from another body on my iPhoneXS . I used this tool for restoring TrueTone and it worked like a charm!
Victor Suenson - Antwort
Hi is there any msg “ iphone canot check your screen”
jason jase -
If your proximity sensor or front camera was changed before. This process won't work.
Safak - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 198
Letzte 7 Tage: 1,298
Letzte 30 Tage: 5,897
Insgesamt: 420,806
