Einleitung
This is the guide of how to repair the James Donkey RS2, and let it work as the new one.
Was du brauchst
The first step is to disassemble all the pieces to make sure all the parts are separated.
Unscrew the small board (including 2 m 2 4 mm screws) to make it easier to figure out where the trouble is.
Then plug it back into the PCB. What we get will be a small board connected to the big board.
Connect the board to the computer, and turn the circuit on to test to see where the problem is.
To figure out if is it connected or not, first open the key tester on a computer that has been connected to the keyboard.
If everything works fine, it should light in green, which means the key has been sensed.
If there is a line that has no reaction, which means PCB is malfunctioning, send it back for repair.
Congratulations! You are done with the replacement. Now put the board back, screw it with 2 4 mm M2 screws, and connect all the cables.
