Zum Hauptinhalt wechseln
How to Fix the Scroll Wheel of a Wired HP Mouse
Was du brauchst
  1. How to Fix the Scroll Wheel of a Wired HP Mouse, How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 1, Bild 1 von 1
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a Phillips #00 screwdriver.
  2. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 2, Bild 1 von 1
    • Gently flip the mouse back over and remove the upper half of the mouse casing.
  3. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 3, Bild 1 von 2 How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 3, Bild 2 von 2
    • Remove the broken axle that has become detached from the scroll wheel.
    • The broken axle may be difficult to locate, but should not have been able to leave the mouse casing unless it has previously been opened.
  4. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 4, Bild 1 von 1
    • Carefully remove all circuit components from the mouse and set on a flat surface.
    • The circuit board is a single unit that should be able to be removed easily all at once.
  5. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 5, Bild 1 von 1
    • Gently remove the scroll wheel by pulling it away from the rotary sensory mechanism.
    • The rotary sensory mechanism is the small green component of the circuit board that detects scrolling movement.
  6. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 6, Bild 1 von 1
    • Place the scroll wheel inside the jaws of the basic pliers such that the broken side is facing up.
  7. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 7, Bild 1 von 1
    • Holding the axle with a pair of small pliers, place a small amount of glue on the broken end of the axle.
    • Be careful to not get glue on yourself or any of the circuit components.
  8. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 8, Bild 1 von 1
    • Place the axle on the scroll wheel in the position of best fit, and allow to sit for several hours to dry.
  9. How to Fix the Scroll Wheel of a Wired HP Mouse: Schritt 9, Bild 1 von 1
    • Return the scroll wheel to the rotary sensory mechanism.
    • The axle should sit over the middle mouse button input sensor which is directly across the circuit board from the rotary sensory mechanism.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
William Riley
169 Reputation
1 Anleitung geschrieben
Texas Tech, Team S14-G6, Cowan Fall 2020 Mitglied von Texas Tech, Team S14-G6, Cowan Fall 2020
TTU-COWAN-F20S14G6
1 Mitglied
3 Anleitungen geschrieben
Ein Kommentar
Props for the effort, but this will not hold for long, glued plastic will snap again soon.
bxsus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 100
Letzte 30 Tage: 401
Insgesamt: 12,202
