Zum Hauptinhalt wechseln
How to Fix the Side Pocket's Elastic on a Backpack
Was du brauchst
  1. How to Fix the Side Pocket's Elastic on a Backpack, How to Fix the Side Pocket's Elastic on a Backpack: Schritt 1, Bild 1 von 1
    • Trim any excess thread and frayed edges from the fabric with your scissors.
  2. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 2, Bild 1 von 1
    • Stretch the elastic to match in length with the fabric.
  3. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 3, Bild 1 von 1
    • Tuck the fabric edge back into the elastic.
  4. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 4, Bild 1 von 1
    • Pin the fabric and elastic together.
    • Working with needles and pins can be dangerous.
  5. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 5, Bild 1 von 1
    • Begin stitching the fabric and elastic together.
    • Start about one centimeter before the tear begins.
  6. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 6, Bild 1 von 1
    • Continue stitching and remove pins when you sew past the part they're holding together.
  7. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 7, Bild 1 von 1
    • Stitch until you have passed the end of the tear by about a centimeter.
  8. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 8, Bild 1 von 1
    • End the stitch by tying a small knot close to where the thread passes through the fabric.
  9. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 9, Bild 1 von 1
    • Cut the thread just above the knot so there is little excess.
  10. How to Fix the Side Pocket's Elastic on a Backpack: Schritt 10, Bild 1 von 1
    • Clean your work space and put away the tools
    • Congratulations, you're done!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Emily Burnside
155 Reputation
1 Anleitung geschrieben
Cal Poly, Team 15-6, Green Fall 2015 Mitglied von Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 96
Insgesamt: 8,271
