Zum Hauptinhalt wechseln
How to Format a drive in Windows 7-10
Was du brauchst
  1. How to Format a drive in Windows 7-10, Open File Explorer: Schritt 1, Bild 1 von 1
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-10, Open the Format Menu: Schritt 2, Bild 1 von 2 How to Format a drive in Windows 7-10, Open the Format Menu: Schritt 2, Bild 2 von 2
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-10, Format your drive: Schritt 3, Bild 1 von 1
    • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
    • Use default allocation size.
    • If you want to rename your drive put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
George A.
21.690 Reputation
4 Anleitungen geschrieben
Community Protectors Mitglied von Community Protectors
Community
18 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 25
Insgesamt: 666
