Introduction
This guide will show you how to remove a punctured tube and replace it.
Read through the Free Wheelchair Mission GEN 1 Tools guide guide to familiarize yourself with all the tools necessary.
  1. Unscrew the axle bolt Using the Free Wheelchair Mission Custom Multi-Purpose Tool on the bolt head and a 19mm crescent wrench on the nut.
    • Unscrew the axle bolt Using the Free Wheelchair Mission Custom Multi-Purpose Tool on the bolt head and a 19mm crescent wrench on the nut.
    • Remove the wheel and set it aside.
      • You can also use a 19mm socket instead of the multitool.
  2. Unscrew the cap of the tube stem and set it aside.
    • Unscrew the cap of the tube stem and set it aside.
    • Release any air that remains by pressing down on the piston in the head of the stem.
    • Take a tire lever and fit it under the edge of the tire.
    • Pop the edge of the tire out of the rim of the wheel by pushing down on the lever.
    • Clip the opposite end of the lever onto the closest spoke.
    • Take another tire lever and repeat step 4 roughly 2.5 inches away from where you are holding the other tire lever.
    • Holding one tire lever in place, slide the other lever around the rest of the wheel until the side of the tire is completely free of the rim.
    • Push the stem of the tube back through the hole in the rim it comes out of.
    • Reach under the tire and pull the tube out.
    • Unfold the new tube and unscrew the cap of the stem.
      • Set the cap aside someplace safe. You will need to put it back on later.
    • Fit the stem of the tube firmly into the hole in the pump that comes on the frame.
    • Lift the lever on the head of the pump up.
    • Pull the handle of the piston at the bottom of the pump out.
    • Pump a small amount of air into the tube so that it holds its basic shape.
      • To pump air into the tube pull the piston out then push it back in.
    • Push the stem of the tube through the hole in the rim so that the head is on the outside.
    • Push the rest of the tube under the tire so it sits evenly on the rim.
    • Push the tire back onto the rim working your hands around the wheel.
    • Pump air into the tube until the tire is firm and can support you weight.
    • Screw the cap back onto the head of the tube stem.
    • If you have a pressure gauge it should read around 40 psi.
    • Put the wheel back on the axle and screw in the bolt using the multitool or 19mm socket and 19mm crescent wrench.
      • Make sure the handle faces out.
Finish Line
Andrew Blocher
58 Reputation
1 Guide authored
Cal Poly, Team 14-7, Maness Spring 2013 Member of Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 898
