Zum Hauptinhalt wechseln
How to Fujifilm Endeavor 100ix
Was du brauchst
  1. How to Fujifilm Endeavor 100ix, Outer Casing: Schritt 1, Bild 1 von 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. How to Fujifilm Endeavor 100ix: Schritt 2, Bild 1 von 1
    • Locate the battery door.
  3. How to Fujifilm Endeavor 100ix: Schritt 3, Bild 1 von 1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. How to Fujifilm Endeavor 100ix: Schritt 4, Bild 1 von 1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. How to Fujifilm Endeavor 100ix: Schritt 5, Bild 1 von 1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. How to Fujifilm Endeavor 100ix: Schritt 6, Bild 1 von 2 How to Fujifilm Endeavor 100ix: Schritt 6, Bild 2 von 2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. How to Fujifilm Endeavor 100ix: Schritt 7, Bild 1 von 1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. How to Fujifilm Endeavor 100ix: Schritt 8, Bild 1 von 1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. How to Fujifilm Endeavor 100ix: Schritt 9, Bild 1 von 1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. How to Fujifilm Endeavor 100ix: Schritt 10, Bild 1 von 1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. How to Fujifilm Endeavor 100ix: Schritt 11, Bild 1 von 2 How to Fujifilm Endeavor 100ix: Schritt 11, Bild 2 von 2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  12. How to Fujifilm Endeavor 100ix, How to Fujifilm Endeavor 100ix: Schritt 12, Bild 1 von 1
    • Locate the CHP Mode Switch.
  13. How to Fujifilm Endeavor 100ix: Schritt 13, Bild 1 von 1
    • Remove any visible debris that may be blocking the CHP Mode Switch.
    • Using the Q-tip gently wipe away any dust, dirt or residue, in and around the switch.
    • Once you are sure the switch is clean, test it gently by sliding it back and forth between the 'C', the 'H', and the 'P'. If the switch is clean there should be very little resistance and the switch should glide smoothly from one mode to the next.
Abschluss
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Eric Nicolai
679 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-5, Forte Winter 2011 Mitglied von Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 2,263
