Zum Hauptinhalt wechseln
How to Get Rid of Urine Stains in the Carpet
Was du brauchst
  1. How to Get Rid of Urine Stains in the Carpet, How to Get Rid of Urine Stains in the Carpet: Schritt 1, Bild 1 von 2 How to Get Rid of Urine Stains in the Carpet, How to Get Rid of Urine Stains in the Carpet: Schritt 1, Bild 2 von 2
    • Fold a dry cloth or a towel and press it firmly over the stain.
  2. How to Get Rid of Urine Stains in the Carpet: Schritt 2, Bild 1 von 1
    • Sprinkle a dash of baking soda on the stain and leave it there for 30 minutes to soak.
  3. How to Get Rid of Urine Stains in the Carpet: Schritt 3, Bild 1 von 1
    • Vacuum the baking soda afterwards to remove the residue from the carpet.
  4. How to Get Rid of Urine Stains in the Carpet: Schritt 4, Bild 1 von 2 How to Get Rid of Urine Stains in the Carpet: Schritt 4, Bild 2 von 2
    • Use a one-to-one (1:1) ratio of dishwashing liquid and water to clean the pee stains on the carpet.
  5. How to Get Rid of Urine Stains in the Carpet: Schritt 5, Bild 1 von 1
    • Use a sponge to spot the solution lightly on the stain until it is visibly gone.
  6. How to Get Rid of Urine Stains in the Carpet: Schritt 6, Bild 1 von 1
    • When the urine is visibly gone, spot with a clean dampened (wet) towel to rinse.
  7. How to Get Rid of Urine Stains in the Carpet: Schritt 7, Bild 1 von 1
    • And then use a dry cloth or towel to remove the excess of moisture on the carpet until it's dry.
Abschluss
Thank you for following along through our guide hopefully this helped you a ton.
David Scherrey III
145 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G121, Cardinal Summer 2020 Mitglied von UW Tacoma, Team S1-G121, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G121
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 57
Insgesamt: 893
