Einleitung
It happens to all of us- you walk a little too close to a desk corner, or maybe you snag your clothes on a tree branch, and you’ve torn your shirt or pants. Don’t fret; there is a way to fix this! This document will offer step-by-step instructions on how to hand-sew a patch onto your clothes using recycled fabric.
Was du brauchst
Use scissors to cut just outside the perimeter of the hole to clean the edges.
Decide what recycled fabric you would like to use as a patch and cut a rectangle just larger than the hole in your clothes.
Lay your patch over the hole to cover it entirely and ensure that the patch covers all sides with seam allowance.
Thread your needle by pulling one end of the thread through the eyes of the needle.
Pull your needle along the thread to the center and pull the thread straight so that the ends align.
Center and place the patch over the hole.
Secure the top edge of your patch using straight stitch, ensuring to pull any access thread through along with the needle.
Make as many stitches as you need to reach the end of your patch, with your final needle position on the backside of your fabric.
Cut excess thread using your scissors, leaving plenty of room for a knot.
Tie a double-knot in your thread.
You're all finished! To remove a patch, carefully use scissors or a seam ripper to cut only the thread used to secure the patch to the base fabric. Be cautious not to cut the fabric.
2 weitere Personen haben diese Anleitung absolviert.
