Zum Hauptinhalt wechseln
How to Hem a Skirt
Was du brauchst
  1. How to Hem a Skirt, How to Hem a Skirt: Schritt 1, Bild 1 von 1
    • Turn the garment inside out.
    • Inspect the hem: Are there any bulky regions along the hem or is it even all across? Is the hem straight or does it have curves?
  2. How to Hem a Skirt: Schritt 2, Bild 1 von 1
    • If your skirt has an existing hem, use seam ripper to remove current hem.
    • Place the pointed end in each stitch and cut it using the blade edge on the seam ripper.
    • Be sure not to rip the actual garment.
    • The example skirt did not have an existing hem.
  3. How to Hem a Skirt: Schritt 3, Bild 1 von 3 How to Hem a Skirt: Schritt 3, Bild 2 von 3 How to Hem a Skirt: Schritt 3, Bild 3 von 3
    • If the skirt is being shortened, wear the skirt inside out and measure the desired length.
    • Use sewing chalk to mark the length.
    • Pin up the fabric along the desired chalk line.
    • If you are only adding a hem, measure and fold 1/2 an inch up from the bottom of the skirt and pin along the edge.
    • You want to wear the skirt inside out so the hem is not on the outside of the skirt.
    • It may help to have a partner mark the desired length of the skirt while you are wearing it.
  4. How to Hem a Skirt: Schritt 4, Bild 1 von 3 How to Hem a Skirt: Schritt 4, Bild 2 von 3 How to Hem a Skirt: Schritt 4, Bild 3 von 3
    • Thread the needle with matching thread.
    • Start with a Backstitch to secure the thread.
    • Stitch along the hem, avoiding the pins.
    • Create a backstitch once you meet the place where you began.
    • For the example images, a darker thread was used for better visibility.
  5. How to Hem a Skirt: Schritt 5, Bild 1 von 2 How to Hem a Skirt: Schritt 5, Bild 2 von 2
    • Cut the thread to detach from needle.
    • Cut any excess thread.
  6. How to Hem a Skirt: Schritt 6, Bild 1 von 1
    • Turn the skirt right side out.
    • Inspect the hem to ensure there are no gaps.
    • Try on skirt for fit.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Safiah Nemr
157 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-3, Andersen Winter 2024 Mitglied von UC Davis, Team 1-3, Andersen Winter 2024
UCD-ANDERSEN-W24S1G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 478
