Einleitung
Learn how to quickly and easily increase the waistband size of any pair of jeans! This repair involves adding elastic to make the waistband bigger. The elastic used in this guide is about an inch wide, so your skin might show through the area where denim was removed near the waistband. You may wish to use a wider piece of elastic to cover the opening, but keep in mind that wider elastic will likely have less give.
This repair requires a sewing needle and scissors, which are sharp, and should be handled with care.
Was du brauchst
Lay the jeans on a flat surface.
Use a measuring tape to measure the waistband of the jeans from one hip to hip.
Calculate the difference between your waistline and the waistband measurements.
Mark 1/4 of the difference on each side of the waistband with a pencil.
Use sewing scissors to cut from 1/2 inch below the waistband to the marking made in Step 3.
Measure the elastic to fit the space that was removed from the waistband with an extra 1/2 inch on each end.
Cut the elastic where it was measured.
Insert an arms-length piece of thread through the needle's eye.
Pull it through the needle so both ends of the thread meet.
Tie a knot at the end of the thread.
Tie a knot at the end of the thread when you finish sewing. Cut off the excess thread.
Repeat steps 3-8 on the alternate side of the waistband.
There you have it, an up-cycled pair of jeans that you can wear proudly instead of throwing away!
