Zum Hauptinhalt wechseln
How to Install Linux Mint on a Windows PC
Was du brauchst
  1. How to Install Linux Mint on a Windows PC, Connect a USB drive: Schritt 1, Bild 1 von 2 How to Install Linux Mint on a Windows PC, Connect a USB drive: Schritt 1, Bild 2 von 2
    • Connect a USB flash drive with at least 4 GB of capacity to the fastest available port on the computer.
    • Use a USB 3 drive connected to a USB 3 port for faster installation. USB 3 ports are usually colored blue and/or labeled SuperSpeed (SS).
  2. How to Install Linux Mint on a Windows PC, Download Linux Mint: Schritt 2, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Download Linux Mint: Schritt 2, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Download Linux Mint: Schritt 2, Bild 3 von 3
    • Navigate to the Linux Mint website and click Download.
    • Select a desktop environment (Cinnamon, Xfce, or MATE) based on the description and screenshot. Select Download on the one you choose.
    • Linux Mint provides regional download mirrors. The file is identical for each. Pick the one that matches your region or preference.
    • Download the SHA‑256 checksum .txt. This will be used to verify the file after downloading.
  3. How to Install Linux Mint on a Windows PC, Verify the download: Schritt 3, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Verify the download: Schritt 3, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Verify the download: Schritt 3, Bild 3 von 3
    • To ensure the file downloads correctly, Linux Mint provides a checksum for each disk image (.iso) file. This is how it's verified.
    • Navigate to 7‑Zip.org and download the compatible version of 7‑Zip.
    • Open the downloaded file and click Install.
    • Right-click the .iso file downloaded in the last step and select 7‑Zip → CRC SHA → SHA-256 to calculate its checksum.
    • Validate the file's checksum against the reference on the Linux Mint download page.
    • Compare file names to find which checksum to compare.
    • Ensure the checksums match perfectly.
    • If they don't match, re-download the file or download from a different mirror (if available).
  4. How to Install Linux Mint on a Windows PC, Shrink existing Windows install (optional): Schritt 4, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Shrink existing Windows install (optional): Schritt 4, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Shrink existing Windows install (optional): Schritt 4, Bild 3 von 3
    • We recommend skipping this step and erasing Windows unless you need it for specific programs.
    • In Windows, open Disk Management. Right click the Start Menu and select it, or type "Create and format hard disk partitions" in the Windows search bar.
    • If you have multiple drives, check the contents of each in the This PC section of File Explorer and note their capacity and model. Right‑click each drive and click Properties then Hardware. This helps prevent picking the wrong drive later.
    • In Disk Management, right‑click the partition labeled C: and select Shrink Volume.
    • Enter how much you want to shrink the existing Windows installation in MB. To convert GB to MB, multiple by 1,024. For example, 30 GB = 30,720 MB.
    • Select Shrink and wait for it to process.
    • Once complete, a new Unallocated partition will appear on the drive. This is where you'll install Linux Mint.
  5. How to Install Linux Mint on a Windows PC, Create a bootable USB: Schritt 5, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Create a bootable USB: Schritt 5, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Create a bootable USB: Schritt 5, Bild 3 von 3
    • This step will erase and overwrite the chosen USB drive with the Linux Mint installer. Unplug all USB drives with important data for safety.
    • Download and install Fedora Media Writer. Click the file ending in .exe. The ones ending in .dmg are for MacOS.
    • Launch Fedora Media Writer.
    • Click Select .iso file.
    • Select the .iso file by clicking the Select... button and clicking it in the File Explorer window that pops up.
    • Select the USB drive you want to be erased and have the Linux Mint installer written to.
    • Double-check everything is correct, then select Write. A window will pop up asking to confirm. Select Write to erase the chosen drive and write the Linux Mint installer to it.
    • Wait for the installer to be written to the USB drive, then select Finish.
  6. How to Install Linux Mint on a Windows PC, Boot from USB drive: Schritt 6, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Boot from USB drive: Schritt 6, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Boot from USB drive: Schritt 6, Bild 3 von 3
    • If you're using Windows 7, restart the computer and repeatedly press F12, F2, or the key specific to your device to access the boot options menu. Skip the remainder of this step.
    • Open the Settings app and navigate to Update & Security → Recovery then select "Restart now" under Advanced startup.
    • You can also hold the Shift key while clicking Restart in the Start Menu.
    • In Advanced startup navigate to Use a device → UEFI: USB. This will boot the computer from the flash drive.
    • If the USB option doesn't appear in this menu, select Continue to restart the computer and try again.
  7. How to Install Linux Mint on a Windows PC, Configure the installer: Schritt 7, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Configure the installer: Schritt 7, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Configure the installer: Schritt 7, Bild 3 von 3
    • The installer will erase the data on the drive or partition you select. Be careful not to accidentally pick one with important data on it.
    • Linux Mint uses a "Live" installer. This means it can run the operating system directly off the USB drive. Take it for a test drive to ensure it's what you expect, but don't judge performance until it's installed on the computer.
    • Select Install Linux Mint to begin the installation.
    • Select the language then click Continue.
    • Select the keyboard layout that matches the computer. It should select it automatically, but use the test field to verify the keys you press input correctly. Click Continue once verified.
  8. How to Install Linux Mint on a Windows PC, Connect to the internet: Schritt 8, Bild 1 von 2 How to Install Linux Mint on a Windows PC, Connect to the internet: Schritt 8, Bild 2 von 2
    • If you don't have internet, skip this step and don't check the Install multimedia codecs box (they can be installed later).
    • Connect the computer to a Wi-Fi network or wired connection to get it online. When using a wired connection, this menu may be automatically skipped.
    • Check Install multimedia codecs, then click Continue.
  9. How to Install Linux Mint on a Windows PC, Select installation type: Schritt 9, Bild 1 von 2 How to Install Linux Mint on a Windows PC, Select installation type: Schritt 9, Bild 2 von 2
    • If you shrank the Windows partition in this step, select the Install Linux Mint alongside Windows option.
    • If you didn't shrink Windows and want to wipe the drive entirely, select Erase disk and install Linux Mint.
    • If you have multiple drives, be careful not to accidentally erase one with important data on it.
    • Click Install Now.
    • If prompted, review the changes and click Continue.
  10. How to Install Linux Mint on a Windows PC, Configure installation: Schritt 10, Bild 1 von 2 How to Install Linux Mint on a Windows PC, Configure installation: Schritt 10, Bild 2 von 2
    • Select your location/time zone using the interactive map or text field beneath it.
    • Enter your name, computer's name, username, and password. Also select whether to require a password to log in or not (you'll still need it to install software).
    • For additional security, check the Encrypt my home folder box.
  11. How to Install Linux Mint on a Windows PC, Boot into the new operating system: Schritt 11, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Boot into the new operating system: Schritt 11, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Boot into the new operating system: Schritt 11, Bild 3 von 3
    • Press Restart Now to restart the computer and exit the "Live" installer.
    • Remove the USB drive once prompted, then press Enter to continue.
    • Use the arrow keys to select Linux Mint from the GRUB menu and press Enter.
    • If you do nothing, the top option will be automatically selected after a few seconds.
    • Wait for the computer to boot.
  12. How to Install Linux Mint on a Windows PC, Installation complete: Schritt 12, Bild 1 von 3 How to Install Linux Mint on a Windows PC, Installation complete: Schritt 12, Bild 2 von 3 How to Install Linux Mint on a Windows PC, Installation complete: Schritt 12, Bild 3 von 3
    • Follow the on-screen prompts to get started with the new operating system.
    • Use the Driver Manager program to find any additional drivers you may need for your hardware to work well.
    • Restore the USB drive used for the installer back to normal with Fedora Media Writer for Linux (available from the Software Manager app).
    • If you're dual-booting and decide to remove Windows, delete its partitions in your desktop environment's Disk Management equivalent. For example, Cinnamon has Disks. Create a new partition to fill the free space.
Abschluss
Congratulations! You've successfully installed Linux Mint on a Windows PC.
Didn't go as planned? Try asking our Linux Answers Community for help.
Eine weitere Person hat diese Anleitung absolviert.
Nick Schultz
36.987 Reputation
224 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 20
Letzte 7 Tage: 122
Letzte 30 Tage: 330
Insgesamt: 898
