Zum Hauptinhalt wechseln
How to Install Shoulder Buttons in Your Game Boy Advance SP
  1. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the hinge pin: Schritt 1, Bild 1 von 2 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the hinge pin: Schritt 1, Bild 2 von 2
    • If the hinge pin fell out when removing the shoulder button, put it back into place.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: Schritt 2, Bild 1 von 3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: Schritt 2, Bild 2 von 3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: Schritt 2, Bild 3 von 3
    • The two springs are not interchangeable. It should be clear if you're trying to install the wrong spring, as it won't fit correctly in the button.
    • Slide the spring into the shoulder button so the bent arm goes into the cutout on the inside edge.
    Frag FixBot
  3. How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: Schritt 3, Bild 1 von 3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: Schritt 3, Bild 2 von 3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: Schritt 3, Bild 3 von 3
    • When installing the button, make sure it's oriented so the spring's straight arm is on top.
    • Use your fingers to hold the spring in place and slide the button over the hinge pin and into its recess.
    Frag FixBot
  4. How to Install Shoulder Buttons in Your Game Boy Advance SP, Push the spring arm into place: Schritt 4, Bild 1 von 2 How to Install Shoulder Buttons in Your Game Boy Advance SP, Push the spring arm into place: Schritt 4, Bild 2 von 2
    • Use your finger, a spudger, or a pair of tweezers to rotate the spring arm into its clip.
    Frag FixBot
  5. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: Schritt 5, Bild 1 von 3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: Schritt 5, Bild 2 von 3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: Schritt 5, Bild 3 von 3
    • Repeat the process to install the other shoulder button.
    Frag FixBot
Abschluss
Return to your original repair guide and continue with reassembly.
2 weitere Personen haben diese Anleitung absolviert.
Spencer Day
191.025 Reputation
1.204 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thanks for adding this small guide, linked from the 'How to Reshell' guide. The springs of my shoulder buttons fell out during disassembly and this made it so much easier and less stressful, knowing I was doing it right. Everything works perfect again, including a stuck button (I had to replace the rubber pad)
CircuitBenT - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 53
Letzte 30 Tage: 189
Insgesamt: 1,348
