Zum Hauptinhalt wechseln
How to Install Toilet Seat Stabilizers
Was du brauchst
  1. How to Install Toilet Seat Stabilizers, How to Install Toilet Seat Stabilizers: Schritt 1, Bild 1 von 1
    • Make sure the toilet and the toilet seat are clean and dry.
    • Put the toilet seat in an upright position.
    • Loop the rubber band through the round screw hole in one of the safety bumpers.
  2. How to Install Toilet Seat Stabilizers: Schritt 2, Bild 1 von 2 How to Install Toilet Seat Stabilizers: Schritt 2, Bild 2 von 2
    • Place the longest flat side of the safety bumper against the bottom of the toilet seat adjacent to any existing bumper.
    • Loop the rubber band around the toilet seat so the safety bumper sits flush and securely against the seat.
    • The perpendicular piece of the safety bumper should fit just inside the toilet bowl when the toilet seat is fully down.
    • Confirm the placement of the safety bumper and adjust it if necessary. Return the seat to the upright position.
  3. How to Install Toilet Seat Stabilizers: Schritt 3, Bild 1 von 1
    • Using a 5/64” drill bit, drill a hole in the center of the slotted hole, not more than ⅜ inch deep.
    • Do not drill through the toilet seat.
  4. How to Install Toilet Seat Stabilizers: Schritt 4, Bild 1 von 1
    • Place one of the screws into the drilled hole and use the screwdriver to tighten the screw only halfway in to allow for adjustments.
    • Remove the rubber band.
    • Repeat mounting instructions on the other side of the toilet seat.
    • Lower the seat and check that safety bumpers are aligned on both sides.
  5. How to Install Toilet Seat Stabilizers: Schritt 5, Bild 1 von 2 How to Install Toilet Seat Stabilizers: Schritt 5, Bild 2 von 2
    • Use the screwdriver to tighten both slotted screws.
    • Screw the anchor screws into round holes.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 37
Insgesamt: 95
