Zum Hauptinhalt wechseln
How to Install Ubuntu Linux
Was du brauchst
  1. How to Install Ubuntu Linux, Download Ubuntu: Schritt 1, Bild 1 von 1
  2. How to Install Ubuntu Linux, Burn to Disk: Schritt 2, Bild 1 von 2 How to Install Ubuntu Linux, Burn to Disk: Schritt 2, Bild 2 von 2
    • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
    • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
  3. How to Install Ubuntu Linux, Boot to installation media: Schritt 3, Bild 1 von 1
    • I recommend trying Ubuntu in a virtual machine, which is what I did.
    • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
    • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
    • If you have successfully booted into the installation media, you will see this picture.
    • Click on the big "Install Ubuntu" button.
  4. How to Install Ubuntu Linux, Install Ubuntu: Schritt 4, Bild 1 von 1
    • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
    • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
    • If you are experienced with partitions, you may use this partition editor.
    • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
Abschluss
That's it! Now you can try Ubuntu all you want.
7 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 55
Insgesamt: 1,389
