Zum Hauptinhalt wechseln
How to Install a Fifth String Shubb Banjo Capo
Was du brauchst
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: Schritt 1, Bild 1 von 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: Schritt 1, Bild 2 von 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: Schritt 1, Bild 3 von 3
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: Schritt 2, Bild 1 von 1
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: Schritt 3, Bild 1 von 1
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: Schritt 4, Bild 1 von 2 How to Install a Fifth String Shubb Banjo Capo: Schritt 4, Bild 2 von 2
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: Schritt 5, Bild 1 von 3 How to Install a Fifth String Shubb Banjo Capo: Schritt 5, Bild 2 von 3 How to Install a Fifth String Shubb Banjo Capo: Schritt 5, Bild 3 von 3
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
Abschluss
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Sara Wier
263 Reputation
1 Anleitung geschrieben
Cal Poly, Team 23-4, Green Winter 2015 Mitglied von Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 52
Insgesamt: 6,845
