Einleitung
Use basic skills and handy work to install a capo that will expand the library of tablature available to your musical abilities. A fifth string capo is intended to adjust the tuning of the fifth (G) string on the banjo without having to constantly adjust the fifth string tuning key.
This installation process can be pretty intimidating, but if you approach it cautiously and double check your measurements, this fix can be empowering and rewarding.
Was du brauchst
Line the capo up along the fifth string side of the fretboard as shown.
Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
Use the drill to drill both holes for the two screws.
The holes should be drilled about 1 cm deep
To use the capo, slide the capo finger down to the desired fret.
Then, tighten the spring knob.
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
thank you. Now, I know how to do and i décide to buy a shubb and to install it
