Einleitung
This guide shows how to install and remove Expansion Cards for your Framework Desktop.
The Expansion Cards are hot-swappable. You can install and remove them without turning off your desktop.
For information on Expansion Card compatibility, click here.
Was du brauchst
Rotate the Desktop so its rear rests on your work surface.
If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
Use your finger to flip the Expansion Card latch into the unlocked position.
Push up on the lip of the Expansion Card with your fingers.
Pull the Expansion Card out of its slot and remove it.
If you need help, contact Framework support.
