Zum Hauptinhalt wechseln
How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom
Was du brauchst
  1. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Open the Battery Compartment: Schritt 1, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Open the Battery Compartment: Schritt 1, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Open the Battery Compartment: Schritt 1, Bild 3 von 3
    • Press down on battery door release tab to flip the battery door open.
  2. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Battery: Schritt 2, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Battery: Schritt 2, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Battery: Schritt 2, Bild 3 von 3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect the Battery: Schritt 3, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect the Battery: Schritt 3, Bild 2 von 2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Identifying Silver and Black Collets: Schritt 4, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Identifying Silver and Black Collets: Schritt 4, Bild 2 von 2
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Silver Collets: Schritt 5, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Silver Collets: Schritt 5, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Silver Collets: Schritt 5, Bild 3 von 3
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Black Collets: Schritt 6, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Black Collets: Schritt 6, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Black Collets: Schritt 6, Bild 3 von 3
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Propeller: Schritt 7, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Propeller: Schritt 7, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Propeller: Schritt 7, Bild 3 von 3
    • Gently press down the motor shaft and lift the propeller up to remove it.
  8. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove Case Screws: Schritt 8, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove Case Screws: Schritt 8, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove Case Screws: Schritt 8, Bild 3 von 3
    • After removing all four propellors, flip the drone over.
    • Remove the following screws from the underside of the drone:
    • Twelve 2.0 mm hex screws
    • Four Phillips #0 screws
  9. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unplug Magnetometer: Schritt 9, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unplug Magnetometer: Schritt 9, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unplug Magnetometer: Schritt 9, Bild 3 von 3
    • Loosen the cable from the plastic landing gear.
    • Unplug the magnetometer molex connector.
  10. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Top Shell: Schritt 10, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Top Shell: Schritt 10, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Top Shell: Schritt 10, Bild 3 von 3
    • Lift up on the top portion of the shell and set it on its side.
    • Do not attempt to fully remove the case. The GPS and Magnetometer cables connect the top shell to the rest of the Phantom, be careful not to stress or break these cables.
  11. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect GPS Cable: Schritt 11, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect GPS Cable: Schritt 11, Bild 2 von 2
    • Lift the GPS cable molex connector up out of its socket on the main board.
  12. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Loosen Magnetometer Cable: Schritt 12, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Loosen Magnetometer Cable: Schritt 12, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Loosen Magnetometer Cable: Schritt 12, Bild 3 von 3
    • Gently pull the slack of the magnetometer cable through the case bottom shell.
    • The case top shell should now have enough slack to work on the interior of the Phantom.
  13. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare G8 Connector Cable: Schritt 13, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare G8 Connector Cable: Schritt 13, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare G8 Connector Cable: Schritt 13, Bild 3 von 3
    • Twist the molex and cable as shown to prepare it for insertion through the case bottom shell.
  14. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Pass the G8 connector through the case: Schritt 14, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Pass the G8 connector through the case: Schritt 14, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Pass the G8 connector through the case: Schritt 14, Bild 3 von 3
    • Insert the molex connector through one of the landing gear holes and case bottom shell.
    • Pull the cable through.
    • This is a really tight fit, take your time and avoid damaging the molex connector or cable. We found that gently rocking the molex connector back and forth through the hole eventually wiggled it through.
  15. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Install the mounting bracket: Schritt 15, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Install the mounting bracket: Schritt 15, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Install the mounting bracket: Schritt 15, Bild 3 von 3
    • Place the H3-2D mounting bracket on the bottom side of the Phantom.
    • Line up the mounting holes and screw in the two bolts to secure the mounting bracket.
  16. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the other side of the G8 cable: Schritt 16, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the other side of the G8 cable: Schritt 16, Bild 2 von 2
    • Twist the other end of the G8 cable molex connector as shown in order to plug in the H3-2D gimbal.
  17. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plugging in the H3-2D gimbal: Schritt 17, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plugging in the H3-2D gimbal: Schritt 17, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plugging in the H3-2D gimbal: Schritt 17, Bild 3 von 3
    • Pass the G8 molex connector through the side of the H3-2D gimbal.
    • Plug in and firmly secure the connector.
  18. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plug in the G8 connector: Schritt 18, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plug in the G8 connector: Schritt 18, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plug in the G8 connector: Schritt 18, Bild 3 von 3
    • Pull the gimbal wire through the case bottom shell and plug in the connector to the G8 plug on the mainboard.
  19. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the Gimbal for installation: Schritt 19, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the Gimbal for installation: Schritt 19, Bild 2 von 2
    • Place the gimbal on the mount with the front facing the same side as the battery cover.
  20. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Mounting the Gimbal: Schritt 20, Bild 1 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Mounting the Gimbal: Schritt 20, Bild 2 von 3 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Mounting the Gimbal: Schritt 20, Bild 3 von 3
    • Mount the four rubber dampers on the gimbal to the mounting bracket.
    • Pinch two sides of the rubber dampers and press it into the mounting bracket holes.
  21. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Ensure the dampers are installed securely: Schritt 21, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Ensure the dampers are installed securely: Schritt 21, Bild 2 von 2
    • Confirm the dampers are installed correctly by twisting them at least 180 degrees.
    • If a damper unmounts, it was not installed correctly. Repeat the previous step for any unmounted dampers.
  22. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Clean up the gimbal cable: Schritt 22, Bild 1 von 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Clean up the gimbal cable: Schritt 22, Bild 2 von 2
    • Pull the excess slack in the gimbal cable up into the body of the Phantom.
    • When reinstalling the case top shell, be careful not to pinch any wires.
Abschluss
David Hoyt
4.023 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
63 Anleitungen geschrieben
Ein Kommentar
Will this work with a Zenmuse H3-3D on DJI Phantom 1?
The Apple Enthusiast - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 4,478
