Zum Hauptinhalt wechseln
LG G3 - How to fix GPS not working
Was du brauchst
  1. LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: Schritt 1, Bild 1 von 3 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: Schritt 1, Bild 2 von 3 LG G3 - How to fix GPS not working, LG G3 - How to fix GPS not working: Schritt 1, Bild 3 von 3
    • Shutdown your phone.
    • Remove the back cover of the phone
    • Unscrew all the screws identified in red in the picture.
    • Remove the plastic covers using your fingernails or a plastic tool.
  2. LG G3 - How to fix GPS not working: Schritt 2, Bild 1 von 1
    • Carefully peel off the 3 metal stickers (connectors) identified in white on the photo with a flat screwdriver.
    • Please note these stickers are fragile and can tear.
    • Cut pieces of a sheet of cardboard or a sheet thick enough to the size of the stickers.
    • Glue a piece of cardboard or thick paper under each sticker to create extra thickness.
    • Replace the stickers in their original location (they will no longer stick to the shell, but that's okay).
    • Reassemble the phone by repeating the previous steps, taking care to tighten the screws properly when reassembling
Abschluss
To reassemble your device, follow the instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
fr en
100%
Hier starten ›
draxx
175 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 1,915
