Einleitung
This Fast Fix will document lengthening a necktie. Tall people have difficulty finding an affordable necktie that fits. Additionally, as teens grow, their ties can become too short. Lengthening a tie is easy and can usually be completed at home, or anywhere else with a sewing machine. It can also be done by hand stitching, but I’ll be using a sewing machine.
Was du brauchst
Measure for the length to add to the tie by measuring from the end of the tie to the belt loop.
Add five inches to that length. This is how long your fabric insert should be.
In this step, measure to find out where to add the extra fabric to the tie, so that the insert will be hidden beneath the collar.
Measure from the clavicle to the belt loop.
Add two inches.
From the widest end of the tie, measure the desired length, in this case, 24 inches.
Mark the spot with a fabric marker. This is where you will cut the tie in Step 7.
Remove the inner white section of the tie by folding outward and placing on the widest part of tie.
Using a rotary cutter on a cutting board, cut the tie diagonally along the section you marked with the fabric marker in Step 3.
Pin the extra fabric along the cut portion of the tie so that added fabric forms a "V."
Pin second portion of original tie in place so that the original tie and the added fabric forms a "V".
After sewing both ends in place, the tie should look like this.
Unfold the inner tie lay it back inside the tie.
Iron the inserted fabric so that it follows the fold pattern of the original tie.
This repair is a great knowledge to have for tall people who wear ties on a regular basis.
